- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi wifi download speed slower than Rogers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys
I got Rogers Ignite internet (500 MBPS) at home with their new Ignite Gateway router/modem.
I tested download speed connecting to that router's wifi usining my iphone 11 pro and iphone XR using speedtest.net app. I got over 500 MBPS download speed but when tested tsted spped on my Orbi network behind this Rogers Ignite Router, download speed dropped to 350 - 400 MBPS.
I will appreciate your hlep..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi wifi download speed slower than Rogers
Your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, may be I was clear in my original post. Ignite router/modem has already been configured as Bridge.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you didn't mention what mode the modem was in.
What FW version is currently loaded?
Swap Lan cable between the modem and RBR? CAT 6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have latest firmware 2.5.1.8 on both router and Satelliet. I am using original flat white Ethernet cable provided by the manufacture.
Secondly, I don't see any issue with the LAN cable because when I test internet speed on Orbi, it is getting well ober 500 MBPS. So there is no Ethernet cable issue at all. Orbi is getting data throughput over 500 MBPS. The issue is only when it goes to wifi it gets dropped to 400 MBPS or llower. It has something to do with wifi settings on the Orbi router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What wireless device are you using to speed test?
Load WiFi Sweet Spots on your wireless device to see the connection rate between the device and the RBR.
Has a factory reset and setup from scratch been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I rebooted Rogers Ignite modem and Orbi router. After reboot download spped is much better now. It hit 550 MBPS download one time as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
