- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Please kindly help with placement of RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Please kindly help with placement of RBK50
No. To some degree however your RBS should help maintain overall signal coverage. AT most you'll loose signal outside the home is all. 50% sill has good coverage at that setting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My 5 GHZ speeds are 250-300 MB.
Yet, the 2.4 GHZ speeds in the part of the house furthest away from the router are only 15-20 MB.
I have set both powere transmissions to 50%. Also, tried channels 1,6,11 Didn't make much difference between the channels.
What can I do to improve these low 2.4 GHZ speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.4Ghz speeds will not be near what you get on 5Ghz. Also device design and support on 2.Ghz will be a factor as well. 1x1 and 2x2 antenna design will be a factor. 4x4 antenna designs have better speed support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ping is rather high, it is in a 13-17 range.
Is there a way to decrease the ping?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is that a wired or wireless result? How are you testing pings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
These are wireless results.
I use two diffrent Android apps. Speedtest and NetSpot to measure ping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pings are about normal. Can be anything between the speedtest site thru up to your wireless device. I recommend wired testing vs wireless. To many variables in wireless for accurate results.
- « Previous
- 1
- 2
- Next »
