- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Forwarding - Multiple Internal IP Problems - RBR10 Orbi Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am getting "moderate" NAT when gaming (Call of Duty in this case) and have two computers connected that I play on - a Dell laptop and a gaming PC. I am trying to port forward to two internal IP addresses but am getting an error message when doing so, using the custom services in the advanced settings.
I have an ORBI RBR10 on firmware 2.6.2.104 with 2 satellites. The laptop is using a wireless connection while the PC is on a wired one.
I have managed to set up up for the laptop but when i try for the PC i get an error saying:
192.168.0.1 says
Custom Service Rule Conflict
The new custom service must not conflict with any existing service rule.
I get the same issue when i try it the other way around. I am using static IP addresses on both the laptop and the PC.
I have also disabled UPnP as that was mentioned in another chain but have had no luck there.
I've attatched a pic of the error I get.
Does anyone know please of any other setting can adjust or change?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have NAT Filter feature listed as a menu item under Advanced tab/Setup/Internet or WAN page on the RBR?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding - Multiple Internal IP Problems - RBR10 Orbi Router
Hi there,
Yes i do, under Advanced > Setup > WAN Setup.
There is the NAT Filtering section with options of Secured and Open, as well as a tick box for "Disable SIP ALG".
I've changed the option from Secured to Open and after restarting everything i seem to have Open NAT in COD on both computers.
Thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can re-enable uPnP as well.
Please mark your thread and solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
