- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with Remote Management orbi rbr40
- Mark as New
- Bookmark
- Subscribe
- Permalink
when i try to select remote managementi get an error message:an occured while activating remote magagement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problem with Remote Management orbi rbr40
What FW is currently loaded?
Is the error appearing on the Orbi app or on the routers web page in a browser?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
fw v.2.2.1.210
fatweb modem dv 2200
in the app of ipad, while in android app it's not possible the configuration because after that i have selected management remote i'm direct to the page of userid and password
this problem is new, few day ago was ok
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you enabled it using a PC and browser connected to the routers web page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
ii tried but not function
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried but it didn't enable it?
What browser are you using?
I would check your modem as well. I believe it has built in router and wifi already:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
enable, but it doesnt't really work. the browser is chrome
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok thank you i try, but the strange thing is that until a few days ago it worked properly and i don't changes anything
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
You might contact NG support and ask for help if needed on this.
