Orbi WiFi 7 RBE973
Reply
RBK23 upload speeds in Router mode
DeividN1
Tutor
Hi there,
Why Netgear mesh systems (like my RBK23) limits dramatically the upload speeds setting up as Router? if I use the system as AP, all works perfect, but in Router mode... I can't obtain speeds over 250Mbps in a 600/600 line. I have try all but I cant solve it. I have the last firmware.
Anybody with the same problem?...
Thanks in advance.
Message 1 of 10
Guru
Re: RBK23 upload speeds in Router mode
Make sure qos, traffic monitoring, parental controls, and access controls are disabled and reboot the router. those can sometimes decrease speeds.
Message 2 of 10
DeividN1
Tutor
Thx for your reply, all this services are disabled, but how can I check if QoS is off? I've read in some site that QoS is default off, it's true?
Message 3 of 10
Guru
What modem/gateway is it connected to? are you running in a double nat?
https://kb.netgear.com/30186/What-is-Double-NAT
Message 4 of 10
DeividN1
Tutor
The ISP modem, is a HGU from Movistar/O2, the typical Mitrastar mounted by this corp like this one:
router-movistar-hgu-930x487
The modem is in bridge mode and all weight of network is over the Orbi RBR, I have single NAT.
Message 5 of 10
Guru
Photos have to be approved by a moderator.
And it wouldn't be the first time an ISP supplied device didn't have a properly functioning bridge mode/passthrough mode.
Message 6 of 10
DeividN1
Tutor
Oh, sorry, I didnt konw.
It would be, but I've see this router (and same ISP) bridged working well with another systems.
Anyway, it's very strange, because when I setup the system for first time, I have the complete bandwith, but If I reboot the router, in this moment I start to have slow up speeds... And allways with a specific speed, without fluctuations.
Message 7 of 10
DeividN1
Tutor
I've check qos, and it's disabled, but my upspeed results stiill bad as can see in the picture.
Message 8 of 10
Guru
Did you try it with the moviestar in router mode and the netgear in access point mode?
Message 9 of 10
DeividN1
Tutor
Yes, I have had it in AP mode and works fine. I’ve search info about this problem, and I find something very interesting... Movistar can’t warranty speeds over ppoe in bridged mode, and I think that the problem is the HGU router. I’ve bought an neutral ONT Ubiquiti for remove HGU. I will receive it tomorrow, when I test it, I will report the results here. Thanks!!!
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1480 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
