- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 Mesh 2.4Ghz Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hoping for some assistance as after reading these forums and Reddit and trying various settings I am still experiecing issues that I cannot seem to resolve.
Issue:
My iMac (2012) and MacBook Pro continually connect to my 2.4Ghz network as opposed to the 5Ghz network while other devices in the same room connect and stay connected to the 5Ghz network. I've tried turning down the TX power to 50% and this does something but then the issue is the devices connect to the 5Ghz and then bounce between the two bands which causes disconnects and it causes issues with my older 2.4Ghz devices. The connectivity on the 2.4Ghz band is awful and changes frequently, it can drop right down to 5Mbps and then jump up to 144Mbps which is causing issues on Zoom/Teams etc.
Ideal State:
Fix the 2.4Ghz random speeds and latency to something more consistent for my older devices
Ensure my Mac's connect only to the 5Ghz band
Configuration:
Firmware: 2.7.3.22
Region: Europe
2.4Ghz
- Disabled 20/40 MHz Coexistence
- Enable WMM (Wi-Fi multimedia) settings
- CTS/RTS Threshold = 2347
- Preamble Mode = Long
- Transmit Power Control = 100%
- Channel = Auto (tried 1, 6 and 11 - same issue)
5Ghz
- Enabled WMM (Wi-Fi multimedia) settings
- Channel = 44
Security = WPA2-PSK [AES]
Enabled Daisy-Chain Topology (1 Router + 2 AP's)
Enabled Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enabled MU-MIMO
Disabled Fast Roaming
Thank you in advance
Simon
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 Mesh 2.4Ghz Issue
Try setting 2307 for CTS.
Try disabling MIMO and Beamforming to see.
If these are the only two devices having problems while others don't, I would contact Apple support as well for help and information regarding there products.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
My guess is the solution will be found on the iMac, rather than the Orbi. Most Windows WiFi adapters have settings for which bands are active. (I have no iMac, but a search turned up this: https://becomethesolution.com/blogs/mac/macos-how-to-force-connect-to-5ghz-or-2-4ghz-wifi-band-same-... )
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks I'm trying this and seeing how it performs during the next day, currently have been monitoring it and while it doesn't appear to have had the desired effect I'll leave it for a little longer
