- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBK50
Hi there,
I have read several options to get the firmware uptodate. Having installed router and satellite very quickly. Great!
However, I get the message "page not found" when I want to go to advanced on my page at orbilogin. What is wrong? I cannot check if I do have the latest firmware.
So, what to do in order to:
a, check the version of firmware (and how to knwo what is the latest)
b. update the thing automatically?
Thank you
Theo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50
page not found usually means something has changed , usually the ip address because the orbi has seen an upstream dhcp server on a connected router
check what ip address your comp has and what default gateway its reporting in its lan stats , this will tell you if the ip address has changed , use the default gateway address to then access the orbi router
