× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR20 constant connection issues
zhoux
Since the update of the mobile phone orbi software, the network disconnection phenomenon often occurs, and it is necessary to turn off the instrument and reconnect the program almost every day. I hope to get an effective solution.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 6
Guru
Re: RBR20 constant connection issues
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 2 of 6
zhoux
cox  internet
Orbi RBR20 router
no satelittle
several other WiFi networks
firmware Version V2.5.1.16
Router and network host next to each other
2500 sq ft home
Mobile computers and TVs use 5GHz
Not sure where to disable the option, and how to view
Message 3 of 6
Guru
Use a PC or laptop and web browser to make any changes to the RBR.
Message 4 of 6
zhoux
I'm sorry I don't understand some of the information you asked me to provide. I have a photo here including some information on the Internet
Can you list what settings I need to make?
thank you very much
Message 5 of 6
Guru
What is the model# of the ISP modem the RBR is connected too.
You'll need a PC or laptop connected to the RBRs web pagr to make any changes. The Orbi app doesn't provide this kind of change feature.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 810 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
