- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
A little more info is needed.
What smart tv are you using? (brand and model number)
Postive it has wifi? I know it sounds stupid but we've had people ask about it with tv's that don't have built in wifi so I have to ask.
Are you able to see any networks if you do a wireless scan?
What error are you getting?
Firmware on RBR20?
How far from the router/satellite are you?
You can try enabling/disabling these features to see if it helps: beamforming, mu-mimo, daisy chaining
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
tv lg oled. smart. From applications only you tube and netflix work. Other applications do not work on wi-fi. When I connect the cable to the modem, then everything works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
LG OLED65C8Y 4K 65 модель телевизора. Вай фай встроенный есть. Работает нетфликс и you tube
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
LG OLED65C8Y 4K 65 TV model. Wifi is built-in. Netflix works and you tube
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
Netflix and youtube have the ability to dynamically adjust resolution and bandwidth based upon how much is available. Not sure about other apps.
What speeds do you pay for?
Are you connected to the 5ghz signal?
Can you speed test with your tv?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
Also, what size is your house?
How many satellites are you running?
Firmware on them?
are they using the wireless backhaul or wired?
Have you tried doing a wireless scan to see if you're on the optimal wireless channel?
