- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Orbi Wifi Wifi Channel selection dropping upload
- Mark as New
- Bookmark
- Subscribe
- Permalink
We installed Netgear ORBI RBR50 Wifi Mesh system (1 base, 1 satellite) in our home a few months ago.
We have a 1Gigabit/second Google Fiber Internet connection.
Most apps (movies, streaming, work laptop, etc.) works well.
However when doing audio/Video calls over Wifi (either zoom calling, Whatsapp calling or Facetime audio/Video),
the upload speed is slow and constantly drops (the other side complains about bad audio/video quality and reconnecting).
When I disable wifi for these calls (so audio/video traffic goes over 4G or LTE), no drops in call quality.
it works seemlessly. However since getting the Orbi, the folks we are talking to over Wifi calls cannot hear us over 20 seconds.. ?
I am not sure of what settings on the Orbi to tweak to fix this issue ?
any suggestions ? here are my current settings
Advanced Wireless Settings (2.4GHz b/g/n) | |
Enable SSID Broadcast | |
Enable 20/40 MHz Coexistence | |
Enable WMM (Wi-Fi multimedia) settings | |
CTS/RTS Threshold (1-2347) | |
Preamble Mode | Automatic Long Preamble Short Preamble |
Transmit Power Control | 100% 75% 50% 25% |
Advanced Wireless Settings (5GHz 802.11a/n/ac) | |
Backhaul Topology | |
Enable Daisy-Chain Topology | |
Backhaul Password | |
Orbi can generate a new hidden password to improve security for its backhaul connection. | |
WARNING: Generating a new password might cause the Orbi satellite to lose connection from the Orbi router. To reconnect, use the Sync button. | |
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices | |
Enable MU-MIMO |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Orbi Wifi Wifi Channel selection dropping upload
You could be experiencing channel interference or possibly you need to open some ports through port forwarding, that support VOIP, WIFI calling, video, etc. You can search for port suggestions on the NET for your specific needs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
I have confimed no ports are blocked.
How do I minimize or avoid channel interference ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ksaheta wrote:Thanks!
Thanks
You can run a program like NetSpot to check what channels neighbors are on and choose a different channel. 2.4Ghz is important as it will get the most interference. I found my channel 1 was less used, so I switched to it. 5Ghz has less coverage area, so you can choose pretty much any channel. I chose 48.
Also check these settings for optimum performance:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
