Orbi WiFi 7 RBE973
Reply
RBR50 Satellites drop connections
HCC202
Star
My system works great for a month or so than my satellites keep dropping offline. Have not moved the satellites or anything with the system. I had the latest firmware in the router and satellites. I reboot the router, but the satellites do not come back on line. They have to be brought back online manually.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
Guru
Re: RBR50 Satellites drop connections
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 710 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
