- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 fails to upgrade/downgrade from V2.5.0.38
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RBR50 that will not budge from V2.5.0.38.
The satelites will update over the auto update feature, but I can not update the main RBR50.
I've tried:
1. Automatic update
2. From phone app
3. Wired PC to RBR50
a) Upgrade to RBR50-V2.5.1.16.img
b) Upgrade to RBR50-V2.5.1.8.img
c) Downgrade to RBR50-V2.3.5.30.img
I've tried this using Edge, Chrome, and a brand new install of Brave browser in incognito mode.
Satellite 1: RBS50 V2.5.1.16
Satellite 2: RBS40V V2.5.1.6
Suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
SOLVED:
First what didn't work:
- Do a Factory Reset: https://www.youtube.com/watch?v=cMw4ePACgc4
- Reset button for 10 seconds. Settings reset, but firmware upload would not take.
- This version of the tftp firmware update. https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
- No orange light on power on.
- tftp would not start even when first turned on.
What did work:
I attempted a 30/30/30 reset and on a whim tried the tftp push at the end of the 30/30/30 reset. The light was blinking red. The firmware pushed and updated. I was able to restore my settings that I had previously saved.
I suspect that the RBR50 has this tftp procedure and I triggered it in the 30/30/30 reset.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
I still used the tftp client from the frist link, but tftp is tftp no matter what client you use.
A few more keywords in case anyone else can't find how to tftp firmware update to the RBR50 when the light is solid green.
SOLVED: tftp firmware update for RBR50 when the light is solid green.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 fails to upgrade/downgrade from V2.5.0.38
@SuperJohn00 wrote:I have a RBR50 that will not budge from V2.5.0.38.
Very strange, because 2.5.0.38 does not appear on the list of RBR50 firmware versions.
The Firmware Update process does not work, and a manual update to any other version also fails. Not good.
My first thought is to
- Save a copy of the configuration (Advanced Tab, Administration, Backup Settings.
- Immediately after the Orbi resets, log in to the Orbi web interface (credentials "admin", "password")
- Attempt a manual firmware update to 2.5.1.8 or 2.5.1.16
- If this succeeds, do another reset and try to "Restore" the previous configuration.
If the previous configuration will not restore, then Factory Reset and configure from scratch. - If this fails, Factory Reset again, log in, and "Restore" the previous configuration
OF COURSE, this is a good time to weigh the "pros and cons". Is the Orbi working satisfactoryily and the urge to update firmware is "something that sounds good to do"? Maybe "if it ain't broke, don't try to fix it." However, if something is not working to suit you, the time and effort spent updating firmware may be well spent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually it is a valid version firmware for the RBR50 and RBS50.
RBR50-V2.5.0.38-1631 22/10/2019I think this was the one that was never available for auto update and pulled because of issues with it, which might explain why the problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
SOLVED:
What did work:
