×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RBR50 poner IP FIJA a los dispositivos conectados.
EnriqueJ
Hola buenas tardes. Necesito por favor instrucciones para poner IP fija a todos los dispositivos que conecte al Sistema RBR50, incluso al mismo Router.
Gracias
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 9
Accepted Solutions
Guru
Re: RBR50 Put fixed IP in the router, in the satellite and in the devices that connect.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 9 of 9
All Replies
Guru
Re: RBR50 poner IP FIJA a los dispositivos conectados.
In inglese per favore
Message 2 of 9
EnriqueJ
Please, I need instructions or explanation to put fixed or static IP, in the router, in the satellite and in the devices that connect to the RBR50.
This is my router.
Thank you
Message 3 of 9
Guru
Refer to page 73 of the user manual for setting "reserved" IP addresses ON the RBR for your devices. You can set a reserved IP address for the RBS as well:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Message 4 of 9
EnriqueJ
Thanks for your reply. In the manual it is indicated that the IPs start with 192.x.x.x., however I have them as 10.x.x.x.
Attached several images for you to check.
If I click add, it shows all the devices, and I select 1, it adds them to fixed IP, I imagine.
The images are in Spanish.
Message 5 of 9
EnriqueJ
Message 6 of 9
Guru
If you have 10.something, then your RBR is configured for 10.0.1.1 or something like that. This only happens if your RBR detects a up stream router in front of the RBR that uses 192.168.1.1. The RbR changes to 10.something to avoid the conflict.
Do you have another router infront of the RBR?
Message 7 of 9
EnriqueJ
Yes I have the router from the Vodafone company.
Router CM DOCSIS 3.0 premium  Compal CG7486E
Message 8 of 9
Guru
Couple of options,
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 458 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
