- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBS50 dropping
The rbs50 is dropping regularly. I have firmware 2.7.0.70. The unit is about 45 feet away. I have it connected to wired network. I can reconnect it by pressing the button on both ends but after a while it shows not connected again on the IOS app. I have no idea what else to try. I hate to throw this in the garbage and get a new system, but I have to have it working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 dropping
Try putting the RBS a bit closer to the RBR. Try 30-35 feet.
Has a full power OFF of the RBR and RBS for 1 minute then back ON...
Disable Daisy Chain on the RBR if it's enabled...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 dropping
I didn't see the wired connection you mentioned.
Is the RBS directly connected to the RBR or is there a switch in between the RBR and RBS? If there is, what is the Mfr and model# of this switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 dropping
