- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbr750 satellites interfering with each other
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ended up unplugging one of the satellites, I was having interference/confusion which led to poor performance (I assume a loop was created). I suspected they were too close to each other and in the end I found that I only needed one instead of two. This was after turning down the radio power. I have a big house but apparently the range is really good and I didn't need the second satellite. Does anyone have similar experience around this or suggestions? I'm not going to plug the second one back in since it works without it, but I'm curious.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbr750 satellites interfering with each other
Are you using wired or wireless backhaul?
I've found it tolerates being to close better if using a wired backhaul.
Otherwise with a wireless backhaul, it needs at least 30 ft between units.
- Mark as New
- Bookmark
- Subscribe
- Permalink
