- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbs50 firmware V2.1.4.16_1.0.0.11 upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbs50 firmware V2.1.4.16_1.0.0.11 upgrade
IF your Orbi is a Verizon version from them, then you'll probably not be able to udpate it to NG stock FW.
You'll need to contact Verizon to see if there if FW for there version of Orbi. Some ISPs do there own FW on NG hardware which required the ISP FW to be loaded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try this:
Download both RBS and RBR FW files...
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
