- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Ring Door Bell
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
It is here on their webpage: https://support.ring.com/hc/en-us/articles/205385394-What-Ports-Do-I-Need-to-Open-in-My-Firewall-for...
If you are faced with a black screen when viewing video and live events in the Ring app, the problem may be related to port settings on your router. In business environments and certain home environments, incorrect port settings can cause device setup to fail as well.
Internet-connected devices, such as Ring products, communicate with the internet by sending information through ports. Ports are designated openings between an internal home or business network and the outside internet. Each internet service sends data through specific ports. For example, Port 80 is used for website traffic.
Ring uses the following ports:
TCP 80
TCP 443
TCP & UDP 15063
UDP range between 16500-32768
UDP 51504/51506
Ports can be “opened” or “closed” on your router’s firewall. Open ports allow devices to send information through them, while closed ports block all traffic. Ring products only function properly if the required ports are open outbound from your router. The process to open ports can be different, depending on your type of router. Consult your router’s user manual for instructions on how to open ports.
Ring Chime also requires certain ports. If your Chime is not ringing, ensure that the following ports are open outbound as well:
TCP 80
TCP 443
TCP 9998
TCP 9999
The client applications also use the following outbound ports:
TCP 7078
TCP 9078
Ring devices and applications do not require any ports open inbound from the Internet on your router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
Must be dumb luck, because Ring doesn't require any port forwarding whatsoever. It establishes its connection outbound and uses push for notifications.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
It's worth noting that the ports listed are required *outbound* ports, not inbound. Ring doesn't need holes poked in the inbound firewall, and thus I've no explanation why his only works in DMZ, unless it's a routing issue.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
I finally got it connected again today, the only differences this time around...
1. Did a hard reset in the ring doorbell; Press and hold orange button for 15 seconds
2. Put my iphone in airplane mode while doing the set up; according to ring support info, the cellular signal sometimes interferes.
My orbi is currently set up as default settings wise (outside of changing ssid and wifi password) since my whole fiasco after the latest firmware install.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
Thank Elvis for this! Was about to chuck 'em in the lake!! I tried most things mentioned up to this point with no joy but this worked straight away.
Login to Orbi on your lap top.
Hit Advanced tab,
Advanced Setup,
VPN Service then changed both TUN Mode Service Type to from UDP to TCP
Then changed TAP Mode Service Ports to 80 on the top and 81 underneath
Bottom line left on auto.
Ring and Chime both saw the network immediatley and are working fine.
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
@see78 wrote:
Still having problems with Ring Pro. Nothing works. I'm beginning to think it's just the quality of the doorbells I'm getting. Id assume that most people have no problems with recording/ live view but I've tried moving the router closer, unplugging the satellite, used an extender and my previous ASUS 68u as an access point. I was sent a replacement but I think it must be bad too. Every other wireless device works flawlessly right now at much greater distances. I even put in a new transformer. My internet speed is fine. I must be getting duds. Gonna to try to get another replacement but my personal experience so far is that this thing is garbage.
what orbi fw? I was having ring doorbell issues but none now post-downgrade (enabled mu-mimo + beamforming + 1.11.0.20 fw + telnet method to disable upgrades)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring Door Bell
- « Previous
- Next »
