- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite disconnecting from RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR50 with one satellite. Over the past few days the satellite has been disconnecting, showing magenta when close to the router, and also showing "good" in the webui. However, when a device connects to the satellite it will not pull an IP from the Router. I've tried moving and rebooting the satellite with intermittent results but it failed again this morning. Has anyone seen something similar or have a way to resolve it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite disconnecting from RBR50
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ghostdog1 wrote:
... showing magenta when close to the router, and also showing "good" in the webui. However, when a device connects to the satellite it will not pull an IP from the Router. I've tried moving and rebooting the satellite with intermittent results but it failed again this morning. Has anyone seen something similar or have a way to resolve it?
"Good" backhual in the GUI with magenta light is a bad combination. Typically, the magenta light should last for about 1-2 mins after blue light, which indicates that the Satellite is in the middle of acquiring IP information from the Orbi. If you have more than 1 Satellite, can you swap their places? Otherwise, move it to the same room as Orbi.
Before swapping/moving, please runs these 3 commands on bad Satellite:
- config default
- config commit
- reboot
If the Satellite is still dead after swapping/moving, then try this solution. If it's still dead afterward, you might be looking at dying hardware. RMA is best friend in that case.
