× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Satellite issue
fatsister
Guide
Satellite issue
I got a refurbished RBR40 converted to a RBS40 satellite and cat5e cable to go with my RBR40 router for house to backyard shop project.
I can get the satellite connected to the router--> my app shows the satellite and router with a green dot.
However, the satellite doesn't seem to be WiFi'ing .  My phone, computer or TV don't detect it.
What setting am I missing to make this work?
Nancie
Message 1 of 10
KevinLiT
NETGEAR Moderator
Re: Satellite issue
Hello fatsister,
Welcome to the NETGEAR Community!
I understand that you are having difficulties adding an additional satellite to your Orbi Mesh system.
Please navigate to the link below for step-by-step instructions on adding your RBS40 to your Orbi Mesh system :
How do I connect a satellite to my Orbi router? | Answer | NETGEAR Support
Best,
Kevin
Community Team
Message 2 of 10
fatsister
Guide
Re: Satellite issue
Thanks for the reply.
I have repeated those instructions at least a dozen times today....no joy.
Nancie
Message 3 of 10
CrimpOn
Guru
Re: Satellite issue
The Orbi 'app' does not provide access to much information about the system.
Perhaps this would be a good time to explore the Orbi web browser interface (http://orbilogin.net )
See page 12 of the user manual: https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Does the Attached Devices menu show the RB?40 connected as a satellite?
Message 4 of 10
fatsister
Guide
Re: Satellite issue
Appreciate the answer.  I have been on the Orbi website
Again, I am connected but sateliite doesn't seem to have a signal.
Access Control: Turned On
General Rule: Allow all new devices to connect
Connected Satellites
StatusDevice NameIP AddressMAC AddressConnection TypeConnected OrbiBackhaul Status
1
Netgear
Orbi53
192.168.1.11
192.168.1.11A0:40:A0:5C:E8:4B
WiredOrbi Router
78:D2:94:52:AA:90
Good
Connected Devices
Message 5 of 10
Guru
Re: Satellite issue
so I kind of go back to the "i converted an RBR40 to an RBS40".  (not really a supported option)
Which requires forcing a firmware it isn't designed to take and then don't know why the wireless on it isn't working.
If you convert it back to an RBR40, does it work? If so, stick that one in the garage hardwired in and run it in AP mode.
Message 6 of 10
fatsister
Guide
Re: Satellite issue
Honestly, I bought this not realizing it was a converted satellite.  I do not know how to convert it back.
I am thinking I will return it and try and find a legitimate satellite that will work with my RBR40.
Thanks for responding.
Nancie
Message 7 of 10
Guru
Re: Satellite issue
If you can return it, I sure would. Sounds like a sketchy situation for someone to sell you a converted device that isn't working.
Take a look on amazon. They had renewed rbk43 kits for pretty darned cheap. That'd get you a backup router  plus 2x satellites to use. Its nice to have a backup router when you have a bunch of money tied up in satellites.
Message 8 of 10
fatsister
Guide
Re: Satellite issue
Thanks.  Took your advice and should have it by Thursday! Nancie
Nancie
Message 9 of 10
Guru
Re: Satellite issue
Hope it works great!
I've had friends/family use those kits and they've worked great so far.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1031 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
