- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting up Orbi backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all
I have just bought the triple pack Orbi as my current Wi-fi is struggling to cope with demand. I am looking for advice on the configuration of backhaul I have planned.
I had hoped to connect one satellite via Ethernet to the Orbi router, simply because I can, but the second satellite will be in an area where wiring to is difficult, my assumption is that communication and backhaul to this satellite will be via the dedicated 5 ghz Wi-fi only. Is mixing the connection types likely to cause any negative effect on the performance overall ?
Another question I have is with respect to the inclusion of an 8 port Netgear switch (unmanaged), this will be part of the wired part of the network, my assumption up to now was that I would connect the wired satellite direct to the Orbi router via Ethernet and hang the switch off the second RJ45 off the satellite, rather than wire the 8 port switch to the Orbi router and hang the satellite off one off the ports of the 8 port switch, is my first thought the best way round ?
The obvious alternative for the system would be all dedicated Wi-fi backhaul and have the Ethernet dedicated purely to the 8 port switch and simply wired direct back to the internet modem.
any advice or pointers would be greatfuly accepted,
PS Also I assume that there are no known issues with the Wi-fi backhaul and potential interference with Sky Q backhaul channel ?
thanks again in advance for any advice and sorry if the above is long winded
Iain
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Setting up Orbi backhaul
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-an...
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure you connect any RBS wired to the back of the RBR directly or thru a switch. You can't connect the RBR and RBS in parallel to a switch infront of the RBR as the status reporting of the RBS will not work on the RBR. Any wired RBS needs to be serially connected behind the RBR.
Yes if you can directly connect the RBS to the back of the RBR, you can hang a switch of the back of the wired RBS.
I would disable Daisy Chain on the RBR as well.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi again
reading first articles I think setting up the Orbi in AP mode may be the safest way forward, is there any real disadvantage over performance with this ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
First off all, thanks for taking the time to give such a comprehensive reply, very much appreciated.
I have been trying to avoid mucking with the modem too much, I have a couple off applications that took a while to get setup and stable , and bearing in mind I know just enough to be dangerous I am scared to blow current config .
i had a scratch about the current set up (ASUS DSL-AC 68U) and there is no issue turning off the radios, and I can disable NAT, so maybe there is scope to modify the existing profile to avoid clashes and save me starting a brand new one again from scratch. The applications that I don't want to upset are security and heating applications that rely on settings through the router.
I assume I can keep the current modem doing DHCP duties so that all current ip's that are fixed remain so, and I also assume that the modem not doing NAT won't affect the applications that are ported through the modem?
sorry more questions lol .
i will read all the papers from the links you supplied and from these I am sure I will manage , I was tempted to go the ASUS mesh route as it appeared so much easier but cost and poor reviews sent down what now appears as a more technically challenging route, and I like a challenge
thanks again
Iain
- Mark as New
- Bookmark
- Subscribe
- Permalink
IMO, if you want to keep things easy and working and stable, use the Orbi in AP mode. I presume during this time frame, stable network and ISP services is crucial and disabling the radios on the host router and letting it due the router duties while Orbi in AP mode will be the best suggestion for your needs. Later on when this time frame passes, then you could make some changes in the system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
yup reading the first article got me there, one thing that I have just got through the daisy chain comment is that the Orbi does not appear to be a mesh system as I had envisaged. I am a little surprised/disappointed in that (assuming my understanding is correct) I don't think it will kill my application or setup but I am not sure if the term mesh best describes the product - maybe it's just a play on words or maybe just me being grounded with other definitions of mesh networks.
dont think this will have me cancelling order but I am going to think a bit about my expectation vs what I am getting
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is your idea of MESH?
Daisy chain is for two or more RBS piggy backing off each other out in a line and not in star formation.
IMO it's a basic MESH system. Nothing ellaborate. It works for what it does. Most Home class systems are simplistic and nothing too complex, though Orbi sure has it's days of seemily being complex when troubleshooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My take on mesh is that it's a self healing multi node network with intelligent optimising routing, each node is connected to as many other nodes as it can and has options to route traffic if one node has an issue, guess with only 3 nodes it's not such an issue and as you say for home use it will be fine and I am sure it will trounce what I currently have, once it's up and running I'll be like "meh"
looking at the manual, there appears to be a lot to play with which can equate to a lot to go wrong , I am going to heed your advice , keep it simple get the basics working and then take it from there. Can you save/backup configurations, just in case a stray thumb causes issues ? Also can I do the initial setup of the Orbi before introducing it to the modem ?
thanks again for the support , it is appreciated
regards
Iain
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya thats enterprise and corporate MESH. You won't see that in home class MESH.
Nice dream though. LOL
Yes, Backup configurations are highly recommended. Saves time when resets are needed.
Yes, you can manually setup the system before introducing the system to the modem. Something I prefer to do unless i'm testing something with a modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again , happy I can do the setup first , on first reading of basic guides i was not clear but happy I can get the basics done and hopefully have a straight forward transition (no laughing at the back please )
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just use a wired PC and you'll be fine.
LOLOLOLOL.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cable looked out, new babies due Tuesday, will devise a plan of attack over the next 3 days, then completely ignore it in the fog of new gizmo utopia that will follow the delivery man throwing the parcel at my front door some 3 hours later than promised !
- Mark as New
- Bookmark
- Subscribe
- Permalink
This will be the rub when the box is delievered only to to stolen by some door dash theif. LOL.
- Mark as New
- Bookmark
- Subscribe
- Permalink
They better be able to run fast ! Working from home, so no real worries I guess 😂😂 will still have to pause breathe and refrain from just plugging them in and shouting "perform you little miracle bundles " 😂😂
- Mark as New
- Bookmark
- Subscribe
- Permalink
We'll keep our fingers crossed for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The one disadvantage with AP mode is that you will not be able to use Circle and Armor. Instead, your router (non-Orbi) will need to be able to provide those functions, or some sort of other product.
I have the exact same setup. One satellite wired, the other wifi. Works great. I have the bulk of my streaming devices on the wire now which frees up the wifi for the real mobile devices. Works great.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for the feedback, I am glad that the wired & wirelss works together, this was one of the reasons I went Orbi instead of the ASUS route, with the ASUS it appeared that wiring a node meant that it disabled the deadicated backhaul and with my exisiting router being dual band I was not really gaining any advantage then, as t0 keep the wireless backhaul on the nodes, they would have to talk to the main router on a non dedicated 5 Ghz wirless - which seems rather stupid. The ASUS modem does have interfaces for both control and access for kids and it has its own built in security that I have always switched off as I ust see it as another overhead - maybe with improved network I may switch it back on again, as a modem and router is is good-maybe I may update to something directly compatible with the Orbi, but thats cost I dont want to add at this time!
cheers
Iain
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope the Orbi is working well now for you.
@IainMcFarlane wrote:Hi, thanks for the feedback, I am glad that the wired & wirelss works together, this was one of the reasons I went Orbi instead of the ASUS route, with the ASUS it appeared that wiring a node meant that it disabled the deadicated backhaul and with my exisiting router being dual band I was not really gaining any advantage then, as t0 keep the wireless backhaul on the nodes, they would have to talk to the main router on a non dedicated 5 Ghz wirless - which seems rather stupid. The ASUS modem does have interfaces for both control and access for kids and it has its own built in security that I have always switched off as I ust see it as another overhead - maybe with improved network I may switch it back on again, as a modem and router is is good-maybe I may update to something directly compatible with the Orbi, but thats cost I dont want to add at this time!
cheers
Iain
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only just arrived today, this evening will be connecting to router to set to AP and to disconnect daisy changing , will also rename the SSID ! Just read back today that you cannot have different SSID names !! Ah well I guess I have some extra work to do in connecting some bits and bobs !!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, You should be fine. Keep us upated on how it turns out. Ya, you'll need to set 1 SSID name so you'll have to go in to the devices and either change them to use the the SSID name or setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far so so I am afraid - getting all my 2.4 stuff back online is not happening easy, also seems to be dropping internet frequently, had put this down to firmware update but less sure . will persevere - need to work out how to switch of 5 Gz try to connect all the 2.4 stuff and see from there
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you need 2.4Ghz only SSID, Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.
Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
You might turn OFF RBS while working with the RBR and devices alone. If you can get it all connected. Then turn on the RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried both options but to no avail- instanly lost 13 client connections on switching over. I have tried to change the ssid of the 5Ghz but for some reason its not sticking- can only assume something in firmware preventing! that was my last resort.
looks like its back in the box and I will just have to scratch my head and see what is what as it stands which is a shame.
