× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Slow Ethernet and Wi-fi with Apple devices
Dornelles
Follower
Hello, I got a Orbi AX4200 and is working well, except with Apple devices ( Imac2017, MacBook Pro 2017, IpadPro2020........
Windows and Android devices are running fast.
It is happening in both wired and wireless environment.
I called Netgear and they said that I have to call to apple and I called to apple and they said that the problem is with Netgear!!!
Message 1 of 2
Guru
Re: Slow Ethernet and Wi-fi with Apple devices
Is the Orbi system operating in Router or AP mode?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Apple wireless issues:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-...
https://community.netgear.com/t5/Orbi/Have-to-keep-rebooting-my-RBR50/m-p/1658603/highlight/false#M4...
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 669 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
