Orbi WiFi 7 RBE973
Reply
Streaming RTSP Camera local Tapo c210 on Netgear RBK53 Orbi AC3000
mikewickens
Hi I got some new Tap cameras C210 was trying to connect via Windows 10 PC using VLC player to Stream using RTSP but I always get a network error. I have tested the ports are open using nmap util.
Scanning 192.168.1.14 [1000 ports]
Discovered open port 443/tcp on 192.168.1.14
Discovered open port 554/tcp on 192.168.1.14
Discovered open port 2020/tcp on 192.168.1.14
Discovered open port 8800/tcp on 192.168.1.14
The Vendor guide - https://www.tp-link.com/uk/support/faq/2680/
Says to open port 554 which I have done on my Orbi router
VLC I try -
Your input can't be opened:
VLC is unable to open the MRL 'rtsp://kitchen:password@192.168.1.14:554/stream1'. Check the log for details.
I have tried many tools ispy and all fail to connect.
My ORBi is set in Router Mode as Im coming from a Virgin Hub3 in modem mode
Could this be camera is connected on 2.4GHZ and Windows PC on 5 GHZ any changes i should try to below settings ?
Message 1 of 3
Accepted Solutions
Guru
Re: Streaming RTSP Camera local Tapo c210 on Netgear RBK53 Orbi AC3000
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 3 of 3
All Replies
mikewickens
I fixed it did a firmware upgrade all sorted
Message 2 of 3
Guru
Enjoy. 📡
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3992 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
