- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WIFI keeps breaking up RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since 3 days our Orbi keeps disconnecting and restarting the Wifi. It mentions "internet not secured" disconnects the Wifi and restarts the Wifi.
The normal internet connection via LAN (cable) keeps working fine.
I have rebooted several times. And the problem is getting worse.
The Orbi has been relatively stable (but not as good as I hoped) . Now the Orbi is basically not usable as a Wifi system.
Any ideas about a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WIFI keeps breaking up RBR50
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mvmp103 wrote:Since 3 days our Orbi keeps disconnecting and restarting the Wifi. It mentions "internet not secured" disconnects the Wifi and restarts the Wifi.
Could you please comment on how many devices exhibit this behavior, and what kind of device they are?
