- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Which ORBI to buy to work with LTERIVERs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.amazon.com/gp/product/B00W73PQGQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
have two of these, one 1/2 way each leg of boomarang house
works with stupid weak Linksys router now BARELY
so don't think I need the 3-piece system, right?
so which minimum ORBI do I buy?
Please no guessing, I really want NO more time invested in MORE experiementation, thanks to Linksys NONsupport and idiot equipment
One story, 1800sf, sheetrock/frame walls, except one has foil faced insulation board on it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Which ORBI to buy to work with LTERIVERs?
Don't use extenders with Orbi. That's what the Orbi satellites are for. Plus those extenders have half the speed of the Orbi 5 GHz client radio (433 vs 866), so you'd be slowing down the Orbi.
For your house, I would probably buy the RBK50 kit. You can add a second satellite later if you need it. My RBK50 covers a 3,000SF three level home, and extends a few hundred feet into the yard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Impressed with 3000sf + yard, same as my son reported
compared to my 1800sf & no yard coverage required.
That said, making sure you read
> boomerang house, router @ hub, most devices here and at extremities
> one direction goes through glass but 50'
> other direction goes through 1-ext. + 4-int. gyp.bd/wood stud walls
is why I was thinking forced into the triad package
ALSO noted
triad kits (perhaps also dual kits) have a satellite wall outlet version vs. larger table top satellites ... thinking plugins would be sufficient for this type house?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@> boomerang house, router @ hub, most devices here and at extremities
ALSO noted
I'm not familiar with the term "boomerang house" but I imagine it's long and curved or "L" shaped.
A diagram would help, but nobody can tell you for sure what system is best, because it all depends on the RF propagation through your walls, the time-varying RF interference at your location, and the placement of your Orbi router and satellite(s.)
However, if you buy the RBK50 or RBK53 kit, you can always add another satellite later if needed. Although the price for one RBS50 satellite alone is pretty high relative to the kit price.
