Orbi WiFi 7 RBE973
Reply
Which satellite models are compatible with RBR50
rampi
Guide
I have RBK50 system (RBR50 router and RBS50 satellite).
I am thinking of getting another satellite(s) to extend/improve the coverage.
Question is which all satellite models are compatible with RBR50 ?
Specifically can I get the small RBK12 and use both those devices as satellites to my main RBR 50 ?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Which satellite models are compatible with RBR50
@rampi wrote:
Was reading up a bit ... I guess my only options are RBS20 & RBS50?
No, any of the options I listed will work. I was just saying the rbs50 and rbs50y both have the 4x4 1733mbps backhaul. The rbs20, rbw30, rbs40, rbs40v all use the 866mbps backhaul. They still work fine and in many cases with a very similar performance.
Message 5 of 6
All Replies
Guru
I wouldn't use the rbs10's.
I'd recommend these:
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50y
reason why is they're all triband. The rbs10's are dual band.
something else to keep in mind is the rbs50 and rbs50y are the only 2 that keep the full 1733mbps backhaul of the rbk50 series you're on. the others use 866mbps.
Message 2 of 6
rampi
Guide
Message 3 of 6
rampi
Guide
Thanks for the info.
Message 4 of 6
Guru
Message 5 of 6
rampi
Guide
Thanks. Just wanted to update that I went with RBS20, with wired backhaul.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 10213 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
