× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Why is my network map wrong
Ninovan
Star
With the last update my Orbi reports that NOTHING is using my satalites. It shows everything connected to the base.   I know this is wrong as each base has at least one PC -Wired- to it as well at close proximity to smart TVs, cameras, iPads, phones, and so on...
It is very hard to diagnose system issues when the limited info the Orbi gives us is wrong.
how do we get a valid network map?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 6
Guru
Re: Why is my network map wrong
Message 2 of 6
Ninovan
Star
Ah setup...
                                              / Satalite #1
Comcast modem >> Orbi <
                                            \ satalite #2
we have about 25 devices, a mix of PCs, amazon echos, cameras, VoIP boxes, media players, smart TVs, iPads, iPhones, printers, plotters, NASs, and an automation server... and a partridge in a pair tree.
the devices are even distributed about the house, so they should be distributed evenly umong the Orbi devices as well...
Message 3 of 6
cool2562
Star
If you upgraded to the new firmware you will need to restore to factory defaults and set up from scratch.
Message 4 of 6
Ninovan
Star
The network counties to function well, everyone is happy with the stability and speed, its just when I go to look at the network to try to head off any problems, the layout is wrong. I know the satalites are working as there are PCs connected to them that are working fine...
if if I didn't go wandering looking and trying to learn I would never know..
Message 5 of 6
Guru
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3442 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
