- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
intermittent internet dropouts RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been suffering intermittant internet issues for a while now and i was hoping that the latest firmware update would have made a differnce but it hasn't 😞
here is a log from the last 3 days. I applied the latest firmware at 10.43 last night (12th)
Failure Start Length
11/07/2019 9:50:57 PM 0:01:59
12/07/2019 8:32:06 AM 0:01:58
12/07/2019 3:24:07 PM 0:03:43
12/07/2019 4:42:37 PM 0:01:57
12/07/2019 9:20:38 PM 0:01:58
12/07/2019 10:43:06 PM 0:01:34
13/07/2019 4:29:14 AM 0:01:59
13/07/2019 4:51:44 AM 0:03:07
does anyone have any ideas? is there a system log for the device that i can check the one i can download from the interface doesn't show information iike interface resets or the error of the system.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: intermittent internet dropouts RBK50
I should also point out that the system doesn't appear to be rebooting at the dropouts as the system uptime (see below) currently goes back to the last reboot (firmware update):
My suspicion is that there is some kind of wan port reset happening but i have no evidence to back this up
CPU Load 40.1914%
Memory Usage(Used/Total) 138MB/495MB
Flash Usage(Used/Total) 2945MB/4096MB
Network Session(Active/Total) 361/65536
System Uptime 10:24:03
- Mark as New
- Bookmark
- Subscribe
- Permalink
This happening with wireless and wire connected devices?
Try a factory reset on the RBR and setup from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Thanks for the response.
i've answered a numbe rof the points below, but the issue is not a wireless issue the disconnect log is from a hard wired machine direct into the Orbi. I've been looking at the logs but not much in there and as its intermittant its difficult to capture the point of disconnect. (only after).
ideally I'd like to get the equivalent of a windows sysem log output to see whats happening at the point of failure. from what is happening it seems more like the WAN interface is resetting but like i said without being able to look at log files at the point of failure its impossible to tell.
I'm going to fire up an external machine an run a test the opposite way to see if that helps with the investigation as I have a static IP from my ISP.
Vodafone ISP Modem - Technicolor TC440VDF HW Ver 3.6.0
Affects only the internet connection wireless internal device connection works
-Done this previously
What is the size of your home? Sq Ft? -
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. - approx 25ft on different floors
a couple but as mentioned not really a wireless issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since the FW was updated?
Is the Orbi system operating in Router or AP mode?
I have not experienced any issue thus far. However mine was updated and a factory reset was performed and setup from scratch. Been online for about a day now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I answered a number of your questions in my previous response??
I Havent completely reset the device since the latest firmware update 2 days ago but have done previously (this has been happening for some time now not just since the last fw update)
the device is in router mode
the issue is solely related to the wan connection I have a stable connection internally both via ethernet cable and also wireless so and also between devices connected on the satellite and the Router unit so its not a wireless or internal routing issue.
the only port that drops is the WAN one. its almost as if its suffering some form of buffer overload and then resetting itself.
However i cant seem to ascertain which logs can give me anything to support this.
Any ideas?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset with the RBR.
Also I would power OFF the ISP modem for 1 minute as well. Then back ON with the ISP modem. Then setup the RBR...
Check that status of the WAN port to see the speed of the connection with the modem, should be 1000Mb, not 100Mb
Might have the ISP check the Modem logs for anything seen on there side during this time when the connection drops.
