Orbi WiFi 7 RBE973
Reply
orbi and nighthawk
bent69
orbi and nighthawk
I got rid of my FIOS cable modem and now am using Orbi as my main router and a nighthawk in AP mode. Nighthawk network has a different name. For some reason, Orbi keeps kicking the 2.4Ghz band of the nighthawk offline. This causes certain devices that are only compatible with 2.4 Ghz type networks offline as well. The 5ghz stay on. This only started happening when I switched from FIOS cable modem to my own Orbi. The nighthawk was always there in A/P mode. Is this familiar to anyone? Any potential solutions?
Thank you all in advance for your input!
Message 1 of 14
Guru
Re: orbi and nighthawk
What Orbi and Nighthawk model units do you have?
Message 2 of 14
bent69
Orbi RBR50 and the nighthawk is X4S
Message 3 of 14
Guru
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? The RBR is not a modem.
Ensure the R7800 is using far separate channels on 2.4 and 5Ghz from what is used on the RBR50.
What is the distance between the R7800 and RBR50? 30 feet or more is recommended.
Message 4 of 14
bent69
I am not sure on the firmware version, but made me think that I should porobably update the Nighthawk one. Trying to remember what I changed the login info to 🙂
Frontier ONT I-211M-L
Names are different and the distance is probably more than 30 feet.
Message 5 of 14
Guru
Ensure the R7800 is using far separate channels on 2.4 and 5Ghz from what is used on the RBR50. R7800 set to channel 1 and RBR set to 11.
Message 6 of 14
bent69
will do, if I can figure out how to log in to the nighthawk 🙂
Message 7 of 14
bent69
Orbi's firmware version is V2.7.3.22
Message 8 of 14
bent69
orbi's 2.4Ghz channel is set to Auto and 5Ghz is set to 48. Should I change the 2.4Ghz from Auto to 11?
Message 9 of 14
Guru
Another think to try as well after checking channels on the R7800, turn downt the power output of the radios. Helps reduce noise and  interferences between the R7800 and RBR.
Message 10 of 14
bent69
so, both routers 2.4Ghz channels were set to Auto. I changed them to 01 and 11 as per your suggestion and will keep my fingers crossed. On your other suggestion, how do I turn down power outputs of the radios?
Message 11 of 14
Guru
Under Advanced Tab/Advanced Settings/Wireless Settings
Message 12 of 14
bent69
thank you!
Message 13 of 14
Guru
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1096 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
