Orbi WiFi 7 RBE973
Reply
original password
wifiblues
Luminary
original password
i am upgrading my orbi router and sattelite to RBK43.  I purchased a used Orbi from a friend.
how do i reset the wifi password back to the Orbi given one?
thanks.
wifiblues
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 6
Accepted Solutions
Guru
Re: original password
I would use a wired PC and web browser to walk thru the setup wizard.
Message 6 of 6
All Replies
Guru
Press the reset button in back for 15 seconds then release. Wire connect up a PC and walk thru the setup wizard.
Message 2 of 6
wifiblues
Luminary
thanks - and do the same function for the satellites?
Message 3 of 6
Guru
No, but you can if yon want to. The login info and pw will be confgured automatically on the RBS once it's synced to the RBR.
Message 4 of 6
wifiblues
Luminary
that sounds easy.  I am just a novice!  Can I set up the new router using the same Orbi app as the current router?  the Orbi app does give an option for a new set up.
when I scan the code for the new router, will the wifi password it is using display?
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1193 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
