- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
performances RBK53 - pretty poor
- Mark as New
- Bookmark
- Subscribe
- Permalink
In this we I installed my brand new RBK53, as substitusion of my previous network based on apple airport.
I've different floor to cover with my network.
I placed 1 satellite on the mezzanine, router in living room, other satellite in the lower flow perfectly below the router (linear distance maybe 3 meters)
I'm very upset of the bad performances, definetly WORSE than the apple devices.
The signal for the satellite in the lower flow are indicated as "not sufficient", sometimes the led turns on yellow.
Is there some option that I can fine tune or it is better to repack these toys and send back to amazon?
thanx!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: performances RBK53 - pretty poor
Is the Orbi system operating in Router or AP mode?
Is the Orbi system a new or refurbished unit from Amazon?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you for your thorough support!!!
Answers:
What Firmware is currently loaded? last one, I did the update after installation
ISP modem I don't know these data, but my connection is 30MBs. My claim is however for the internal network speed, and mostly lack of network coverage
Orbi system operating in Router and NEW
Any Wifi Neighbors near by? Yes One + guest
thanx for the hints, I'm going to test this evening!
In the meanwhite, that's the status
As I wrote, distance between router and satellite 2 is 1 floor, 3 meters in vertical.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MarcoBru wrote:thank you for your thorough support!!!
Answers:
What Firmware is currently loaded? last one, I did the update after installation. To confirm, v2.5.1.8?
ISP modem I don't know these data, but my connection is 30MBs. My claim is however for the internal network speed, and mostly lack of network coverage. Test both wired and wireless speeds?
As I wrote, distance between router and satellite 2 is 1 floor, 3 meters in vertical. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Answers:
What Firmware is currently loaded? last one, I did the update after installation. To confirm, v2.5.1.8? Just cheched now, Router Firmware Version V2.3.5.30 😞 Where can I find 2.5?? this one is recognized as the latest one
I have a NAS connected in satellite1, and a smart tv on satellite 2, now I can't stream HD video that with airport connections used to run fine
30 feets should be fine, in my case we are talking of less that 10 feets (with flooring in between). as sq feet, we are talking about 1600 each floor
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.netgear.com/support/product/RBK50.aspx
Please find the Mfr and model# of ISP modem if you have one.
30 feet is Minimum distance between RBS and RBR. Includes flooring. Unless your building is made of concrete and metal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:
can you please confirm that mine is the latest firmware?
Actually, the Orbi router is in PPOE mode, I suppose I can consider itself the modem.
So, as expected "poor" for a much shorter distance is very strange, also considering that the apple setup was creating the mesh network without big issues
___
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the FW update on the RBS first then RBR lastly. Factory reset and setup from scratch. I would add the RBS later and just test with the RBR alone.
If the RBR is working in PPPoE mode then there is a modem before the RBR and the RBR is just interfacing with the PPPoE account from your ISP service.
Is the RBS out at 30 feet?
Try this, turn OFF the RBS and just leave the RBR on. Speed test thru the RBR. What devices do you have connected?
Does a wired PC have good speeds vs wireless?
If the Orbi doesn't work well after all this, you may have a faulty system which needs to returned or replaced.
