- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rbk22 update firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
good day,
trying to manually update firmware to latest version but failed. from 2.2.1.210 to 2.3.0.28.need help thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rbk22 update firmware
Update the RBS first to v28.
What browser are you using? Try IE11 or FireFox broswers
Besure to unpack the .zip file...
What OS platform are you using? Windows or Mac?
- Mark as New
- Bookmark
- Subscribe
- Permalink
used mac on safari and will try suggested thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There should be a IPv6 setting either under Basic or Advanced Tab
- Mark as New
- Bookmark
- Subscribe
- Permalink
Once in the IP6 setting tab look for the drop-down at top right corner probably that says something like AUTO CONFIG. That dropdown is where you can select DISABLE for IP6 -- e.g. it only disables IP6 when selected.
