Orbi WiFi 7 RBE973
Reply
satellite will not connect
Reego
RBK50 satellite will not connect , blinks white then just stops ?  Help , worked for 1 day now will not connect ?
Message 1 of 8
vajim
Master
Re: satellite will not connect
Does the white go away to nothing?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Message 2 of 8
Reego
yes white just goes away stops blinking on both
Message 3 of 8
vajim
Master
if the white goes away, that means you're good to go...
what makes you think the sat is NOT connected or connecting?
I hope you're not using the app, if so, try logging in at the web using the login there.
Message 4 of 8
Guru
FW same version as whats on the RBR?
Message 5 of 8
vajim
Master
He's still checking out the lights
Thanks anyway
Message 6 of 8
Guru
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 7 of 8
vajim
Master
Thanks anyway
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 932 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
