× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
v2.7.5.6 more unstable?
stevenhar
Star
Since updating to the latest firmware v2.7.5.6 for RBR50 / RBS50 I've noticed at least two crashes, there may have been more.
Has anyone else noticed increased instability since updating from v2.7.5.4?
Also you would have thought if they we're fixing security issues they would have updated the SSL certificate so it worked with chrome, I mean come on guys, while you were at it...
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Guru
Re: v2.7.5.6 more unstable?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 11
stevenhar
Star
Had another restart, so definitely something not right.
I have just tried the full system reboot, will monitor and try factory reset + restore if its still an issue.
Message 3 of 11
Guru
If the FR and setup from scratch fails, then might revert back to prior working version of FW.
Message 4 of 11
Joelcc
Guide
I have an RBR50 + 2xRBS50 and also experience almost-daily network disconnects since upgrading to 2.7.5.6
I've tried all the usual reboot steps including my fiber modem and powering each NetGear device one at a time slowly.
Doesn't seem to help. I now regret  applying the firmware update.
Warning to others: Don't upgrade unless you need to. If it's not broken, don't upgrade.
Message 5 of 11
stevenhar
Star
The problem is the only information provided was it was a security update, which are typically important to apply and without any details we can’t make an informed decision.
It sux there would be this type of regression though and if the restart doesn’t help I am going to regret updating. But I guess worst case is having to manually downgrade
Message 6 of 11
Guru
If the Factory Reset and setup from scratch fails, then might revert back to prior working version of FW.
Message 7 of 11
stevenhar
Star
Reverted to V2.7.5.4 and no problem since, so clearly a serious issue with the V2.7.5.6.
Message 8 of 11
Guru
Since this series is EoL and newer FW may not be the best, you might give Voxels FW a go. I've had his on my 50 series years ago. Worked well. Enjoyed that you could add some other features to the system.
Good Luck.
Message 9 of 11
CrimpOn
Guru
All firmware versions for Orbi systems can be found by entering the model number in this page and then selecting "Downloads":
https://www.netgear.com/support/
Message 10 of 11
Dubhlaine
Initiate
Thanks for posting this, I've been burned before updating older products with the latest firmware. I'll stay with the working one for now. Many Thanks 👍
John
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1356 views
  • 8 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
