- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Alternatives to orbi?? (considering replacing already)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Alternatives to orbi?? (considering replacing already)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You'll need to use to use the telnet method then. Seems like your ability to block using your host router isn't working.
@stu3886 wrote:
Firewall blocks definitely didnt work... orbi has forced updated to latest v4 again 😞
No wonder so many people box these up and return them!
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RBK752(v.5) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@FURRYe38 wrote:You'll need to use to use the telnet method then. Seems like your ability to block using your host router isn't working.
@stu3886 wrote:Firewall blocks definitely didnt work... orbi has forced updated to latest v4 again 😞
can you recommend which Firmware is the best to downgrade to so that this can be done?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I think I saw a post you had the 8 series, if so, "last version of FW that has Telnet on the debug page is V3.2.11.2. All versions beyond that do not have telnet on the debug UI web page,"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@FURRYe38 wrote:I think I saw a post you had the 8 series, if so, "last version of FW that has Telnet on the debug page is V3.2.11.2. All versions beyond that do not have telnet on the debug UI web page,"
Downgraded to V3.2.11.2_1.2.13 and have telnet in to disable upgrade on the router. I cant work out how to do this for the satellites though? is it required?
Will the satellites still upgrade themselves automatically even if the router is saying service unreachable?
Model Name Device Name Current Firmware Version Status
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Good question.
Looking at the users post regarding the telnet method, he seems to inidicate that both RBR and RBS needs that telnet config:
4. Enable Telnet option on both Router and the Satellite in their Debug.html page.
5. Telnet connect to both devices, and ran the following code to block.
Seems that the RBS need this telnet config as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
so i ran all the below on the RBR and both RBS's and it still says status V4.6.3.16 for the satellites 😞
the router is all good and says service unreachable, but very worried about the satellites auto upgrading.
nvram set auto_upgrade_enable=0
nvram set ver_check_https_svr1=http.fw.updates1.aaa.com
nvram set ver_check_ftp_svr1=updates1.aaa.com
nvram set ver_check_ftp_svr2=updates1.aaa.com
nvram set ver_check_ftp_svr3=updates1.aaa.com
nvram set lang_check_ftp_svr=updates1.aaa.com
nvram set install_fw_upgrade_latest=0
nvram set ver_check_enable=0
nvram set ver_check_ftp_password=aaa@aaa
nvram set control_cloud_backend_fw_url=https://http.fw.updates1.aaa.com
nvram set promotion_server=updates1.aaa.com
nvram commit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, lets give it a day or so and check back and see if the RBS updates on there own.
Maybe @Xcelebric can comment on this RBS state?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If I will upgrade in the future I will likely go for another Orbi! 🙂
Few main things that I noticed affecting the stability of Orbi systems:
1. Make sure you don’t have multiple NAT routers if Orbi is set in Router Mode.
2. Make sure no devices in the network causing loops (devices that both have Ethernet and wifi capabilities can cause loops). Orbi is sensitive to this.
3. If you use Ethernet backhaul then make sure to pair the satellites first using wireless backhaul then connect the cables and pair again.
If Orbi is correctly setup it will just work. This is my experience since I changed to Orbi around 4 years ago.
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750, Wired/Wireless Backhaul / Orbi RBR50 + 6x RBS50 + RBS40V, Wired/Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@ekhalil wrote:
I have 2 Orbi systems in 2 houses and both are working perfectly well using the very latest firmware versions.
My setup is a simple one, I literally only have orbi in AP mode. its definitely a firmware issue as when I roll back everything works. (until it forces the automatic update!)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Back to the topic, looking at Costco, they have TP-Link Deco AX5700 and Linksys Velop AX4200 systems. Any experience, thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It would be recommended to visit those Mfrs forums and look to see what there users are experiencing with there products. I presume those users would have more information and experiences and post about it there.
Remember this is a NG forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I would not recommend TP-Link anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Reading https://www.reddit.com/r/LinksysVelop , second-guessing myself ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ASUS ZenWiFi AX6600 currently on sale on Amazon. Going to order that one while my Velop order from Costco stuck somewhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
UPDATE:
So I'm still on Firmware version V3.2.11.2_1.2.13
The satalites still havent auto-updated (even though they are still showing that the update is available) fingers crossed I haven't jinxed this by going into check because it just said "downloading firmware" for both satellites so lets hope it continues to not auto update them!
The orbi phone app shows devices connected but doesn't recognise any of them so just has everything listed as "Unknown" (instead of iPhone, printer, fire tv etc like it used to show before on the later firmware, not sure if this is a known issue with this earlier firmware?)
Images in Microsoft outlook are very slow to load or don't load at all. (I often have to click open in browsers to view emails with images now)
Couldnt connect my wifi printer easily like I could on later orbi firmware but gotaround this by manually typing in the SSID and password and that worked.
Everything else seems to be working ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@SergeL wrote:
Installed ZenWiFi, what a breeze of the fresh air! It took no time to configure and switch, changed DHCP, and WIFI SSID to match, and everything is up and running. Returned RBR753 back to Costco after almost one year, no question asked, saved $100.
can you add additional nodes to the asus zenwifi? currently have orbi router + 2 satellites and need the satalittes so that I can plug sky q multiroom into them via ethernet. (they don't play nice on non-sky wifi)
