Orbi WiFi 7 RBE973
Reply
Device not showing up under "Attached Device" in console
brandobot
Guide
On my RBR850, I connected a device via wifi. On the device itself (while connected through bluetooth), I can see my device has an IP of 10.0.0.83. From another device on my network, I can ping this device.
However, If I go to "Attached Devices", I am unable to find this device. How can I get it to show up?
Message 1 of 9
Guru
Re: Device not showing up under "Attached Device" in console
What device are you referring too?
Message 2 of 9
brandobot
Guide
Firmware 4.6.3.16
Modem is Arris bgw210.
The device connected is a Bobcat 300 Helium miner.
Message 3 of 9
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend option #2.
What browser are you using?
Does the Orbi app experience same thing with this device not appearing?
Is the device connecting to the RBR or RBS that you can tell? Look at the RBS web page as well.
Might review this as well:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-v...
Message 4 of 9
brandobot
Guide
My modem has wifi disabled. I have ip passthrough configured and my orbi is in router mode.
I’ve used chrome and safari browsers on my windows, mac and iphone. I’ve also tried the Orbi app from iPhone. The device is closest to my rbr, but i can check the rbs page
Message 5 of 9
Guru
Also ensure the devices FW or SW is up to date on the device?
Message 6 of 9
brandobot
Guide
Yep, and the device is reachable on my network. I’m able to enter the IP on my browser and reach the device’s page
I plugged in my old netgear nighthawk is able to see the device.
Message 7 of 9
Guru
Sounds like a possible host name thats not being captured by the Orbi system from this device.
Has a full power OFF of the ISP modem, RBR, RBS and all devices for 1 minute or longer then back ON been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
You might try to update the FW to what I linked you to.
Message 8 of 9
ekhalil
Master
Do you have SPC (Smart Parental Control) activated?
When the new SPC is active the way the Orbi app handles attached list and the list’s format is different.
I noticed the same issue with devices not showing in the attached list (of online devices) and the device will show as not online although the device is online!. What I do to get the device again is to “remove the device” then with the next refresh it will start to show correctly in the list.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2515 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
