Orbi WiFi 7 RBE973
Reply
Enabling AX Not Available - RBR750
avalpert
Hi, I can't seem to figure out how enable (or check that it is) the AX features on my Orbi RBR750. In the wireless settings there is no checkbox next to 'Enable AX' (see attached picture) and my computer says that my router is oeprating as AC - what am I missing?
Message 1 of 9
Guru
Re: Enabling AX Not Available - RBR750
Can you post a picture if what you see on your RBRs web page?
Message 2 of 9
avalpert
It's Firmware 3.2.16.6_1.4.4. Attached is a screenshot of the homepage
Message 3 of 9
Guru
Now navigate to Basic/Wireless Settings. What do you see here?
Message 4 of 9
avalpert
Screenshot attached.
Message 5 of 9
Guru
The two check boxes next to Enable 2G and 5G are the AX mode enable boxes. When these are checked, AX mode is enabled. Removing the check in the boxes then applying the change disable AX mode.
Message 6 of 9
avalpert
I see, then can you think of a reason my computer (with an AX wireless card) would think the access point is an AC?
Message 7 of 9
Guru
It's not connecting at AX modes.
Drivers are not up to date...
Something to ask the Mfr of this PC about.
Message 8 of 9
Mikey94025
Hero
What operating system is your computer (e.g., Window or Mac) and how does it indicate to you whether the wireless network is AC or AX?  Most phones don't tell you whether the network is AC or AX so let's verify what you're seeing on your computer.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1941 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
