bmwr75's avatar
bmwr75
Star
Dec 14, 2021
Fiber Modem and Orbi connectivity problem
Recently purchased the Netgear Orbi RBK753S High-Performance Whole Home Mesh WiFi System from Amazon.  Cannot get it to work when connected directly via ethernet cable to my Adtran SDX 621 fiber modem.
If I connect the fiber modem to the wifi router that came with the Adtran modem from my ISP and then to the Orbi router via a LAN ethernet connection, it works fine (wifi radio turned off on the ISP router).
BUT, am unable to configure remote access to my NAS file server when going through the ISP provided wifi router because it cannot be put in bridged mode (locked out of that function in the Admin menu).
Any suggestion on what to try to eliminate the need for the ISP provided wifi router?
  • bmwr75's avatar
    bmwr75
    Dec 17, 2021
    My ISP did an update on their fiber modem ONT and the Netgear Orbi started working as it should after a restart.
  • CrimpOn's avatar
    CrimpOn
    MIght start with the Adtran community forum: https://supportcommunity.adtran.com
    Search the knowledgebase for things like "how to connect wifi router"
    Or, a call to the ISP tech support line.  Surely you are not the first customer to want to remove the router.
    What model of WiFi router did the ISP provide?
    How is the WiFi function disabled (web interface or button on the case)?
    I agree completely.  Two routers (Double NAT) make remote access to NAS very difficult.
    (along with a host of other potential issues)
    • CrimpOn's avatar
      CrimpOn
      another approach is to try connecting a computer directly to the ONT with an ethernet cable and see what happens
    • bmwr75's avatar
      bmwr75
      Star
      Called my ISP today and tech support said many of their customers use their own routers and mine should work fine.  FYI - the Google Mesh router this Orbi replaced didn't work either when connected directly to the fiber modem via ethernet cable.
      I turned off the radio on the ISP provided router in the router's set up menu.
      • CrimpOn's avatar
        CrimpOn
        sometimes it helps to power off the ONT, attach the WiFi router, power on the ONT, (wait a minute until the network light comes on), then power on the WiFi router (Orbi).  Enter the Orbi web management interface and see what it says about the WAN connection.
