Orbi WiFi 7 RBE973
Reply
Firmware V3.2.15.25_1.3.15 - Media Player Buffering
antonjosh
Can anyone help me why all of a sudden our Roku and Firesticks have started buffering after the upgrade to the new firmware for our AX6000? I followed what everyone have suggested to change CT to 2347, remove the 20/40 coexistence, and I even changed the 2.4ghz to 6 so as not to interfere with another AX router in my neighborhood but the players are still buffering. My satellites are all wired with CAT6 and the main living room TV has one satellite behind it. Prior to the upgrade, everything was fine. I have an RBR router and 2 RBS satellites. I am really getting tired of Orbi AX and thinking of reselling it so I can try the Asus ZenWifi. Too much trouble for a super expensive router.
Message 1 of 4
Guru
Re: Firmware V3.2.15.25_1.3.15 - Media Player Buffering
Downgrade back to v11.2.
Message 2 of 4
antonjosh
Yes I did it for all 3. Is there an order of resetting it?
Message 3 of 4
Guru
Not really, I would reset the RBR first then RBS lastly as if you do the RBS first and you don't reset the RBR quick enough the RBS could auto re-connect by themselves.
I acutally reverted back to v11.2 not for buffering however for NEST controller problem. See if this works for you.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 702 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
