Amirlit's avatar
Amirlit
Guide
Dec 15, 2021
Iphone wifi6 Support?
Hi There, so can I get the Iphone 13 max to connect to Wifi6 or 6e? I enabled Wifi6 only on the router, but I still cant see the SSID in my list of avaliable wifi networks. I only see the 5ghz.
Thoughts?
Amir
    We need to wait for newer devices for 6E.  Current iPhones do not support Wi-Fi 6E: https://kb.netgear.com/000064176/Does-my-Apple-iPhone-iPad-or-Mac-support-WiFi-6E
    Apple iPhones, iPads, Mac computers, and Pro models of each do not support WiFi 6E and cannot access the 6GHz wireless band.
    • raven_au's avatar
      raven_au
      Virtuoso
      On the iPhone 13 you will get Wifi6 if you your router supports Wifi6.
      You won't get Wifi6e, the iPhone 13 doesn't support it.
      • Amirlit's avatar
        Amirlit
        Guide
        That doesnt seem to align. I turned on Wifi 6 only on the router, but I dont see the SSID in the list on my Iphone 13 Max.
      • CrimpOn's avatar
        CrimpOn
        There is a difference between WiFi6 and WiFi6E.
        WiFi6 means 802.11ax, which all of the Netgear 'AX' Orbi's support.  This is a new encoding in the 5G WiFi spectrum.
        WiFi6E is a totally new in the 6G radio spectrum.
        One tiny letter (E) makes all the difference. Perhaps it would be entertaining to do any internet search on WiFi6E
