- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 960 system and 850 satellites - Confirmed working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just so folks know, the 850 satellites will work with the 960 system. I saw some previous posts that thought otherwise but I have the system up and working fine right now. One is hard wired into 960 router and the other is using wireless backhaul. Both are working fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 960 system and 850 satellites
Really...what FW version are you using on the 8 and 9 series?
Please post a screen capture of the 9 series connected clients page...And what was the process to get them synced?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure, see attached (Scrubbed out Mac addresses etc).
960's running v6.0.3.85_3.1.15 and 950's running V4.6.9.11
Process was like normal: I hard reset the 850s with a needle, initiated the satellite pairing sequence on the orbi web interface, plugged in the 850s again to power, when prompted I hit the sync button on the 850 and then it relatively quickly indicated it found the satellite and paired.
Once paired, I moved one to another room wireless backhaul and the other I attached to ethernet for backhaul, which didn't require any tweaks to config. Just spun right up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 960 system and 850 satellites - Confirmed working
Wow, confirmed:
Can access the RBS web page.
Interesting it seems connected at WPA3:
Wondering if this would be backwards compatible with non WPA3 devices. Mixed WPA2 and WPA3 is set on the RBRE960.
- Mark as New
- Bookmark
- Subscribe
- Permalink
7 series RBS working now too:
Thought the status reported Wired for unknown reason when the RBS was synced wirelessly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you post a screen capture of the statistic page from the RBR while you have the RBS850 connected to the system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which specific page, not sure which one is the statistics page
- Mark as New
- Bookmark
- Subscribe
- Permalink
The one under the Advanced Tab page. There is a button there call Show Statistics.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also do you have Guest Network enabled on the RBR and if not, do you see any Guest Network SSIDs coming from the 8 series RBS?
