- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK 853 and Orbi Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am based in the UK and live in a "large house", which suffers from poor WiFi and WiFi dead spots.
I am considering investing in a WiFi 6 Network System, as there at least 30 devices on the network regularly, not all of which are mobile.
Can someone please explain to me the difference, other than the cost, between these 2 Netgear systems?
1. Orbi Pro WiFi 6 Tri-Band AX6000 WiFi System Pack of 3 (SX80B3)
2. Orbi WiFi 6 System (RBK853) AX6000 [https://www.netgear.com/orbi/rbk853.aspx?_ga=2.124363530.1205809823.1603710812-538524941.1602322963]
So far all I have managed to gleam, from the volumes of Web Data is, that the SX80B3 system is designed for the Business environment and the RBK853 is targeted for the home environment.
Also does anyone have any experience of using the updated Orbi App for iOS devices, apparently released about 5 days ago? Is there any significant difference in terms of providing parental controls etc.
Thank you and appreciate your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK 853 and Orbi Pro
Review the data spec sheets on NG web site for each model to compare:
https://www.netgear.com/support/
Also be sure to visit the Orbi Pro forum for additional help and information regarding the pro version:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
For any Orbi app questions, help and information, please post in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-ap
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi FURRYe38,
Thank you for the information.
Having reviewed the Specs, I am of the view that the Orbi WiFi 6 RK853 would be my preferred option.
I do have a follow up query
The link to the app you sent, returns a Node not Found message. I have pasted the link belelow
Is there an alternative link?
To reitherate, my query which is does the updated Orbi App provide parental controls?
Thank you
MSS37448
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Sorry about that, it was malformed...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you FURRYe38
the new link works.
Have a nice day
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi FURRYe38,
Would you know if I can use Orbi RBK 853 with my ISP Router, by just turning the WiFI Radio off [i.e. do not switch the ISP Router into Modem Mode}. Would this work and are there ny drawbacks with this approach?
Thank you for yiour help and patience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
