Orbi WiFi 7 RBE973
Reply
Orbi RBS50y V2 wont sync with Rbk752
BradPruitt
Initiate
I am having trouble syncing the outdoor satellite to the new router.
Does the RBK752 and the RBS50Y have compatiblity?
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi RBS50y V2 wont sync with Rbk752
From what I userstand, the RBSY needs to have Extender mode FW loaded on it, then it should work with Orbi AX systems.
Message 2 of 4
All Replies
Guru
Message 2 of 4
BradPruitt
Initiate
Thanks, I was going to try that if nothing else worked, but it worked perfectly!
Message 3 of 4
Guru
Good to hear. Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 712 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
