Lewes1973's avatar
Mar 23, 2022
Orbi Wifi6 (RBK850+RBS850) + Philips Hue + Homekit issue
Hello All,
I recently bought and installed an RBK850+RBS850 combo to exchange my old Amplifi HD setup. Devices are running on the latest firmware (4.6.7.13) connected to each other wirelessly.
There are around5 wired connections to RBK850, including a Philips Hue Hub.
There are around 40 wireless devices, from which 2 iPads connected using 5Ghz network, running 24/7 utilizing Apple Homekit to manage all the smart devices in my house.
The environment is up only around a week, but there is an issue I can't fix: after around 3 days of operation, both iPads (not simultaneously) start to react to changes towards the Hue lights quite slowly. I press a button (in the Homekit app) to turn on/off a light, and it takes around 20-25 seconds to execute. Other devices seems working fine.
The only solution I found, that I disable the wifi on the iPad(s), enable again, and it is fast for a few days.
The 5Ghz network is running on channel 36, Preamble mode automatic, CTS/RTS is 2347.
Any suggestion for a fix?
  • FURRYe38's avatar
    What happens if you disable AX mode on 2.4Ghz on the RBR?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • Lewes1973's avatar
      Lewes1973
      Tutor
      AX mode is already disabled on 2.4Ghz, but the devices connected to 5Ghz, where it is enabled.
      The house is 100squaremeter, the router and satellite is around 8 meters to each other, but the router is in a rack cabinet, plus there is a door between the 2 devices.
      • FURRYe38's avatar
        Try disabling AX mode on 5Ghz and see.
        10 meters would be preferred between the RBR and RBS and in between each RBS...
