Orbi WiFi 7 RBE973
Reply
RBK-752 RBK-753 AX4300 Hardwire Ethernet ports throttle limited to 100Mbps?
SirRadiodude
Installed RBK-753S w/ gig fiber net
Wifi speeds accurately reflect gig fiber speeds via wifi5 and wifi6 adapters, but ports on coming off main router are only outputting 10/100 not 10/100/1000.
First (most obvious) troubleshoot was confirming router firmware is up to date and cable is not damaged. Firmware is current, cable tested out, but multiple cat6 and 5e tested to confirm... no change. Running SAME cat6 & 5e cables off satellite AP ethernet ports yield wifi-like speeds (500+).
What could be throttling my hardwire connections?
This makes ZERO sense! Could certain settings be causing this?
Haven't done hard reset of router yet because it will be a PITA so saving that as last resort.
Any advice appreciated.
TIA
Message 1 of 3
CrimpOn
Guru
Re: RBK-752 RBK-753 AX4300 Hardwire Ethernet ports throttle limited to 100Mbps?
What is connected to the router LAN ports with ethernet?
Message 2 of 3
Guru
Any progress on this?
TIA
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 348 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
