Orbi WiFi 7 RBE973
Reply
RBR750 light keeps flashing white and wifi network is not visible
ottostar
the light on my router keeps flashing white, the wifi network is not visible to the device but in the GUI shows as OK. The satellites are not showing as connected either.
Message 1 of 8
tucsontico
Virtuoso
Re: RBR750 light keeps flashing white and wifi network is not visible
To provide you with accurate advice, we need some information about your Orbi setup:
1) What firmware is installed on the router (RBR) and the satellites (RBS)?
2) What brand and model modem or optical network terminal (ONT) are you using?
3) How many satellites are installed?
4) What troubleshooting steps have you taken so far, e.g., power cycle, factory reset, etc.?
Understand that members on this forum are just volunteering our advice. We are not Netgear employees.
Message 2 of 8
ottostar
1. - Firmware RBR750-V4.6.3.7_2.0.49
2. - I don't think it is relevant since it was working for over 2 years without issues same modem and same ISP.
3. - 2 satellites attached.
4. - Troubleshooting:
     - Power cycled router and satellites
     - Downgraded firmware.
     - Restored from backup.
     - Factory reset router and satellites.
Internet access worked and works over wire, only the WIFI network is is an issue, neither WIFI network is visible to any of my devices.
Message 3 of 8
Guru
What CAT# lan cable do you have between the RBR and modem/ONT? CAT6 is recommended.
Factory reset and setup from scratch with out loading the backup from file.
Power off both RBR and ISP Modem/ONT for 1 minute then back ON with the modem/ONT then RBR.
Message 4 of 8
ottostar
I have tried setting up the devices from scratch, no luck with that. The base starts blinking white as soon as the Wifi config is saved and the satellites fail to be added.
The wired devices connected to the router have internet connectivity. Any idea why the wireless networks would not be available?
Message 5 of 8
Guru
Try try updating FW as well to v.2 seen this this forum...
Message 6 of 8
ottostar
Thank you all for the replies and the suggestions.
I would like to emphasis ONLY THE WIFI is NOT working, meaning the WiFi networks main and guest is not showing up in the list of available WiFi networks.
ALL devices connected to the RJ45 ports have internet access, for that reason I am positive the issue is not with the cable or modem.
Did any of you experience the same issue?
Message 7 of 8
Guru
So please give feedback to the question presented...
Try try updating FW as well to v.5 seen this this forum...
My 7 series has been online since yesterday, aside mysterious reboots, wifi has been ONLINE always.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1024 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
