- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850+Nighthawk MR5100 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an ATT cellular modem (Netgear's MR5100) connected to the Orbi 850 router with two satellites. I am having NAT 3 issues with my PS5. I have tried putting the PS5 in a DMZ, port forwarding, etc. I switched from secure to open NAT in the orbi admin MR5100 and not something I can change. Does anyone else have this setup, and if so have you dealt with this problem? When I set up my home system, in the MR5100 settings, I turned on IP passthrough, turned off DHCP, disabled ethernet standby, and switched the usb-c to charge only. Then I connected it to my Orbi. Any help would be appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850+Nighthawk MR5100 issues
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2...
