- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RBR850 debug screen No Telnet Option
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 debug screen No Telnet Option
I would like to confirm with you, the oldest version you mentioned is 3.1.5.23?
Also would you please list out the procedure of downgrading the firmware?
such as, downgrade RBR/RBS first?
Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you downgrade, downgrade the RBS first then RBR lastly. Same FW update proceedures for manually updating FW on Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
May I also have the version number which still have the telnet enable option?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try V3.2.15.25_1.3.15
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for so many questions, I would like to ask one more question, if I change the SSID for 2.4G in V3.2.15.25_1.3.15, and the RNR will auto update to the latest version, so will my configuration still applied after the RBR auto update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF the FW auto updates to recent version, telnet options will be removed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR850 How to set 2.4G and 5G ssdi separately?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have found that firmware v3.2.18 does not appear to allow you to down grade firmware any longer as it warns you are doing so and ONLY allows you one option of "NO" to proceed.
This is really starting to go the wrong direction with firmware updates.. I purchased these as they had more control over network config than Googles WiFi mesh system offered via just an app .. this is very disapointing to say the least !
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible that this post has co-mingled two different Orbi models:
- RBR50, which had telnet on the debug screen until V2.7.3.22 took it away.
This model can enable telnet using the Python script. - RBR850, which has not had telnet for some time.
And I have no idea if the Python script works on this model or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I didn't catch that. Good catch CrimpOn. That version he posted is for the RBS50 series. The one I posted is for the Orbi 8 series which was last version of FW that supported Telnet.
This model can enable telnet using the Python script.- RBR850, which has not had telnet for some time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CrimpOn wrote:Is it possible that this post has co-mingled two different Orbi models:
If it could at one point, it seems it can't anymore. Certainly not working with my RBR50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have to downgrade to a previous version. I think v104 still had telnet.
NG seems to be removing telnet from Orbi systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Give it a try. There is a Windows Telnet Enabler.exe as well that may work.
It doesn't work on Orbi AX systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then try downgrading FW to bring telnet back in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats seems to be there choice.
- « Previous
- 1
- 2
- Next »
