Orbi WiFi 7 RBE973
Reply
RBRE960: I'm having same 400 Bad Request problem
Pauly6String
Tutor
Was it a factory reset or reboot?  I'm having same 400 Bad Request problem.
Message 1 of 6
Accepted Solutions
Re: RBRE960: I'm having same 400 Bad Request problem
Make sure the device name doesn't contain any special characters like &
I noticed I had the same issue with one of my devices I was trying to reserve. Removing the special character fixed the 400 Bad Request problem.
NG could do a better effort here and print out a more descriptive error message than the generic "400 Bad Request".
Message 2 of 6
All Replies
Message 2 of 6
Pauly6String
Tutor
Re:RBRE960: I'm having same 400 Bad Request problem
"Make sure the device name doesn't contain any special characters like &
NG could do a better effort here and print out a more descriptive error message than the generic "400 Bad Request"."
About ten seconds after I made my post I changed my router name from Orbi Wan (with space) to Orbi-Wan and that fixed it.
Thanks for the reply.  Been a month trying to figure it out
Message 3 of 6
Guru
Re: Re:RBRE960: I'm having same 400 Bad Request problem
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 4 of 6
Pauly6String
Tutor
I have made a CONFIG file now that I have 95% of my devices using an assigned IP now.  Orderly, ah!!
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1147 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
