- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS750 will connect Ethernet but not wireless
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR750 with two RBS750. One of the satellites works fine. But the other one will not connect. I have done a couple of resets already and it still will not connect. If I connect by Ethernet it will connect and I found that it had an older firmware so I upgraded that to the same as the RBR and other RBS. After upgrade it still will only connect by ethernet and not by wireless. Running Ethernet through the house to connect it is not an option. Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS750 will connect Ethernet but not wireless
@R0ck3tman wrote:RBR750 with two RBS750. One of the satellites works fine. But the other one will not connect. I have done a couple of resets already and it still will not connect.
Did you only reset the RBS750 satellite? If yes then it's inconvenient, but trying to reset everything (including the RBR750 main router) could bring things back. It's unusual that your satellite will connect wired but not wirelessly to your main router.
