Orbi WiFi 7 RBE973
Reply
RBS850 rebooting after firmware downgrade
spiceyux
Star
After a recent firmware upgrade, I was having some troubles with DNS resolution on my RBR850/RBS850x2 system. After a lot of troubleshooting I narrowed it down to the router. Though, that's not the focus of this post.
I did decide to roll back to a previous firmware where I'd had no issues. V4.6.3.16 for both router and satellitesafter also factory resetting all of them prior to rollback (wanted as few variables as possible).
I have successfully set back up the the router and one of the satellites. However, the second satellite has yet to sync.
A few things I see/notice:
  1. It appears to be constantly rebooting.
  2. I have done a 30/30/30 reset on it, more than once.
  3. I have attempted to sync in close proximity to the router, no good.
  4. I have attempted to sync via direct ethernet connection between the two using a known good patch cable.
  5. Running lan scans (while direct wired) I see it come up as both x.x.1.250 and x.x.1.191.
  6. When it shows green (per attached lan scan) I can briefly log into it directly via web UI using default credentials (admin/password)
  7. However, on the occasion where the login succeeds, I can only see the left navigation and no body content. And there is no indication of the firmware currently being run.
Is it possible the firmware didn't take on that satellite? All indicators suggested success, like the other one. If so, recourse? Upgrade the router again to try and sync?
Any other thoughts/suggestions/back-doors would be greatly appreciated.
Finally, I did reference this post: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/RBS850-Satellite-Constant-Rebooting-... but didn't see much to help or that it was a similar situation.
PS, on the upside, with the router and functioning satellite, the DNS issues are gone!
Message 1 of 10
spiceyux
Star
Re: RBS850 rebooting after firmware downgrade
Well, I mucked around with it some more. Eventually decided to run nmrpflash on it. This is the unbricking tool that uses Netgears underlying NMRP protocol.
Interestingly, when I flashed it with the v4.6.3.16 chk image I'd used on the "good" satellite, it still wouldn't sync.
So, I flashed it down to v3.2.18.1, and then it was able to successfully attach and sync to the RBR850, running v4.6.3.16.
I then went back and tried the online flash update via the RBR850 web UI. "Update failed"
Next, downloaded and flashed it to V4.6.3.9 which was successfully uploaded, however, still couldn't attach/sync to the RBR850.
Now, rolled it back to the v3 firmware and it connected again. THEN I checked to see if the firmware might auto upgrade, and lo and behold, there it was. So, I initiated the firmware update to v4.6.3.16 upgrade, which it appeared to do... and now won't connect again to the base...
At this point, once my family can deal with me tearing apart the network again, I may try rolling all devices (RBR850 & RBS850s) down to the v3.2.18.1 firmware. Then, we'll see if we can slowly upgrade it all back up to v4.6.3.16.
Again, any thoughts/opinions on this, would be very appreciated.
Message 2 of 10
Guru
I would have tried using NMRP too to put v.16 on the RBS initially.
Message 3 of 10
spiceyux
Star
Thanks, that's what I'd hoped and have been trying to go at it methodically but now I'm just kind of scratching my head a bit. I'll tear it apart and report back in the next few days.
Message 4 of 10
Guru
You don't happen to still have local v2 files do you?
Message 5 of 10
spiceyux
Star
Unfortunately, no. I'm just pulling from what I can get here: https://www.netgear.com/support/product/rbr850.aspx#download
Any particular reason? Tear it down to the studs, so to speak?
Message 6 of 10
Guru
During the phase people started posting seeing problems of there systems not working, I manually downgraded mine to v.16 then let it sit over night and it updated to v.2 fine and continued to work. This was before NG took down v.2.
Was curious if you had the local v.2 files you could manually update everything to v.2 and run it. Others have posted they were able to re-update everything manually and it was fine.
Message 7 of 10
spiceyux
Star
Well, tried it a few times, but in short...
30/30/30 reset router and both satelites.
NMRP Flashed them all to v3.2.18.1.
Setup from scratch a new network, all three synced fine and maintained sync after reboot.
Initially, firmware auto updates were hit or miss on their availability, etc.
Considered @FURRYe38 comment about leaving them overnight to upload on their own, had some errands, so left them alone for about 2 hours.
On return, all three reported firmware upgrade available to v4.6.3.16, so ran it.
Upon reboot, same situation, router and one satellite syncing fine. The same satellite, that had issues before, fails to sync.
Something about the v4.*.*.* just really does not agree with this satellite.
Message 8 of 10
Guru
One thing I noticed when I let the 8 series AU, As I was checking for updates using the RBRs web page, only one of my RBS would see or mention there was something available. The other I believe said failed to check for updates. What I did was I broght that one RBS into the same room as the RBR, turned out the power on the RBR to 25%. I had the RBR re-check for an update and low and behold BOTH RBS reported seeing something available. I let the system go over night and check the next morning and it was all back on v.2, back then.
You might try this with this one RBS near or in same room as the RBR. Wondering if the distance is just enough that the FW is failing to update this one RBS correctly.
Message 9 of 10
spiceyux
Star
Yeah, these last activities, I've had them, all three, sitting next to each other. Also, just repeated the 30/30/30 on all three and flashed them to the v4.6.3.9 and attempted to set up a new network from scratch. Couldn't do it. That same satellite keeps failing to sync on the v4 firmware. I don't think it's a question of the firmware taking, just something about that satellite really does not like starting with v4 from scratch.
At this point, I'll have to break down and contact support. Appreciate the sounding board @FURRYe38 and if nothing else, this thread is good documentation.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1184 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
